1 - 3 of 3 Posts
I’ve got a few questions about the ram I bought a couple weeks ago and other things
-What is “Infinity Audio”? Is it from the car brand Infinity?
-How could I fix the cracked dash?
-is the vacuum broken if my cruise control doesn’t work and I can’t shift out of 4x4 High?
-Should I install a remote starter for it?
-How many Kiwi extended cab shortbeds were made with a manual?
Those are the questions and thanks in advance
Kiwi extended cab
Infinity Audio was an upgrade over the stock system.
Replace it.
Dodge Ram Plastic Dash Caps & More
the vac line going to the Cruise actuator(under the battery) almost always breaks, So check that. The cad on the front axle is vac controlled but that has nothing to do with moving the lever.
As for remote starters they are great if you live in a cold environment.
Replace it.
Thanks for the info. I am planning to move to Wyoming and if I do it’s cold there. Also that’s we’re a W250 and a Dakota sit. The infinity audio I saw in the Dakota
1 - 3 of 3 Posts
