1 - 2 of 2 Posts
96 caravan, 3l. Fans will stay on after van is shut down. Happens randomly. Changed control modulator under the air box and was fine for 3 months. Now doing it again. In 3 days it has turned on randomly twice, It has never stuck closed. What do I do? Scanned it: "Rad Fan Control Relay Circuit open or shorted" Cycled relay test with scanner, everyhting seems fine. Where do I look, or replace...thx
fan relay
Get this replaced , it is bad . It is located on the side wall underneath the aircleaner box . This was a recall item back then you may be able to get them to replace it free if it has not already been done before. It is just a little about 2 inch square electronic relay .
1 - 2 of 2 Posts
