1 - 2 of 2 Posts
96 Caravan 3.3 Going Into Safe Mode All The Time.changed The Trany Mode,pcm,both Sensors And Wiring Connections And Nothing Changed.scanner Says Its Loosing Switched Batt.im Thinking Its Batt Volt To The Trany But Dont Know.anyone Had Trouble Like This Or Could Lead Me In The Right Area To Look At.
I'd check your battery, battery cables and alternator. Lots of places will load-test the battery for free. I've found (from experience) that battery cables can look fine -- just a little green where they're bare at the terminal -- and be rotted right through, causing all sorts of goofy electrical issues. The alternator is the least likely candidate. The ones in these vans are plenty stout, and not a known trouble spot.
I'd also make sure you got the right tranny fluid and filter when you had your last flush done. You did flush this transmission at least every 50,000 miles, right?
Rick
1 - 2 of 2 Posts
