Found a spot where all 3 camshaft sensor wires were exposed and touching each other after the van shut down on me. & Gave me crank no start no spark condition. Grabbed 4 spare ASD relays, new crank & cam sensors, still no spark. Checked connector going to coil and every pin is dead, 12v doesn't light my test light during crank or when turned to the on position. I also don't hear the fuel pump initialize from under the van. The exposed cam sensor wires show voltage at supply & signal wires, the plug for the crank sensor does the same. The tach was counting crank when it first shut off on me, after a few crank/start attempts, that quit happening too. Any ideas? Ordered a vin matched PCM awaiting a ride to pick it up.
