i just recently purchased a 94 intrepid and drove fine for a few days.now it is blowing antifreeze towards the back of the motor and i mean like emptying all over the place ,any ideas would be great please help!!!!!!
First check your basic part. Thermostat, waterpump, radiator. You might need to get you radiator flushed.try to figure out where the antifreeze is coming from.
Don't flush your rad you will be waisting your money...you need to get a coolant pressure tester and put pressure in your cooling system to pinpoint the leak...if it is leaking as bad as you say finding the problem shouldn't be to difficult
I wish I had seen this earlier. Had the same problem. Turned out to be a head gasket failure between the water jacket and the atmosphere right in front of the fire wall. Must've been a flaw from the factory. No damage, but quite a days work.
