Yesterday my wife's van was reluctant to start (very unusual) but did start after several cranking cycles and seemed to be running as usual. Backed out of driveway and started down the street, only she would not shift out of 1st
GEAR/LOW RANGE. Park, Reverse, Neutral and Low only! Drives fine in Low!?
Tranny fluid level is fine and bright so, after skimming the Caravan forum, I believe the Throttle Position Sensor may be the culprit and since it's a relatively inexpensive item I ordered one from a local parts store and will install it tomorrow.
Any advice would be welcome, as I'm afraid the cost of a tranny rebuild would exceed the van's (other than sentimental) value.
