hey peoples , im new to these forums , and im hoping to solve a problem.
I have a 93 intrepid with issues .
3.3l v6 ES edition
It all started a year or 2 back .
At normal operating temperature , and while driving , the motor stalles out , cruise control goes on , tonight it died in the middle of an onramp wich was really fun to try to control.
At any rate , at first attempt a couple years back , the cam sensor was replaced . this made no difference . Next the crank sensor was replaced , and this took care of it for about the last year or so .
here it is , a year later , and it almost acts the same as it did before .
I took it into the garage and they disengaged the cruise control unit , thinking. This didnt do anything for it , as a matter of fact the cruise light is still going on and off .
then i was getting a mil code for 02 sensor , so i replace both of those , wich by the way is something very easy for just about anyone to do .
it got rid of all the codes , but still didnt get rid of the problems.
Next , I took it to the dodge dealership . the said some wiring cluster was shortin out on the steering rack , and replaced it . they also took care of the suspension and other shifter recall item at no charge .
got it back and same thing.
After getting it home tonight its getting a code 77 and 52 , the 52 is for an idle air control (AIC) wich has to do with idle air mixture , sometimes it idles a little messed up , wich would explain things , like start up and such . the other , a 77 is something to so with speed control relays .
Im thinkin one of 2 things , either the computer is finally almost toast , wich i hear usually around 150-160k miles go bad ......
OR ... the crank angle sensor is either shot or needs to be replaced again .
I really hate to have to get rid of the car , i love everything else about it ,and was actually planning on a ground effects body and all that , but not until i solve this first .
I have seen alot of post on the same exact issues with other intrepid owners on forums boards , but it seems stop posting after they figure it out , so anyone like me ,never finds out the SOLUTION to the problem .
If anyone has any info that may help , i would be very grateful .
this problem is starting to drive me nuts and cost me plenty trying to troubleshoot .
THANKS , Mike
3.3l v6 ES edition
THANKS , Mike
