I have a 1992 dodge carvan...it's the 3.0...it currently will not start. Before it stopped starting, it would maybe once a month or so stall out at a stop light. I dont mean that it would rough idle and the stall out, I mean it would just shut off. Then I had a bad bearing on the drivers side, so it's been in my driveway since. That's when these problems got worse. When i could get it to start it would be rough and then stall out. Now when trying to start it, it will crank till there's no tomorrow...but it will not start. I changed the fuel filter in hopes that it was just a clog and would explain the rough ideling before the van decided not to work, but that was no help. I do not hear the pump hum like most cars do when you turn the igition to the run position. I can't really remember a time when it did make any kind of noise. I was wondering if maybe it could be one of the following:
1) Fuel Pump
2) ASD
3) Clogged fuel line
4) Bad injectors
I am sort of in the dark on this one...It was my grandfathers van, and Although it has 250,000 on it...If it is something not too bad to fix, I would like to try. If you have any suggestions I would greatly appreciate it!
1) Fuel Pump
2) ASD
4) Bad injectors
