here's a run down, i found a 1991 dakota short bed 2 wheel drive that i'm thinking about playing with street/strip. i just don't know if i should keep the pcm with the OD trans or old school this thing.
i know the rear end will need to go so what interchanges with these year dakotas?
i think i read you can change the rotors to an early dakota 5 bolt rims instead of the 1991 factory 6 bolt rims. but what is the pattern size on that early 5 bolt rotors?
what about the stock trans, is there a high stall convertor around 3k rpm and will it hold roughly 650 hp?
do they make a fuel injected intake to fit W2 heads?
here's the specs on the engine.
"X" block engine, block casting # is 4104230-318-6 casting date is 5-7-79 it is a 4 bolt main block, bore is 4.071.
Bill Miller aluminum rods and Bill Miller forged pistons with 12.5-1 compression with total seal rings.
Chrysler forged radiused billet 3.51 stroke crank with 8 bolt flange.
oil gallery sleeved for roller cam.
Engle solid Roller cam int. lift is .660 ex. lift is .671 duration @.050 int. is 278 and ex. is 287 with 108 centerline.
new-W2 cast iron heads ported & polished and flowed.
Edelbrock Victor jr. intake that has also been ported & polished.
intake valves are 2.08 and exhaust valves are 1.60 and they are the long stainless type.
10* titaniam retainers and 10* locks.
Norris stainless roller rockers 1.6 ratio steel rocker shafts stands and harden rocker shafts.
Crane 3/8" special length heat treated heavy wall pushrods.
