1 - 6 of 6 Posts
I bought a 03' 9.25 rear end and it has the rear discs on it and the main reason I got it was for the TRACLOC diff but I was wondering if the discs would go on my older 9.25 rear end. And do they have different discs I could use to put on my smaller bolt pattern axles? or would some off like a dakota fit?
I know that, There is still some dodges with the 5 4.5 bolt pattern and was wondering if I could just use some of them. And How do I loosen the bearing spacer adjuster things beside the differential bearings? I saw someone made a tool for it but IDK how to do it and my differential wont come out it comes about 1/4 inch out and then wont do anything PLEASE HELP
Aka Force Fed Mopar
There's a hole on the right that you go through I believe.
And you can't use the 5x4.5" axles w/ the 5x5.5" rotors. You may be able to use the newer 4x4 axles, like 81?-up, but you'll still have 5x4.5 up front unless you change those too. There are no 5x4.5" discs that will fit that setup. Dakotas are 6-lug.
And you may want to check the spline count on the differential, sometimes they change stuff like that.
There is a tool that goes through the axle tube to loosen the adjusters. I think some of the cherokees came with disk brake 9.25's and the 4.5" pattern. You might also check some of the ford stuff. I put a set of rotors off a Mercury Grand Marquis on mine.
I have a 9.25 with rear disc out of a 75 chrysler imperial if your close to me i'd even load it up and driveit over but I live in Ontario
1 - 6 of 6 Posts
