:help: It's a 318 Ram van. The current situation is voltage at the injectors, but no fuel. I hear the pump run when the key is turned on. First indication of trouble was no action when the key turned, then it died when going in to gear a couple of times and was hard to start, then just turning over w/o starting. Couple of weeks later, new plugs dist. cap, rotor and fuel filter, still no fuel at the injector despite voltage there when cranking. No engine codes discovered.
