Hi. I have an 84 W150, 360 4 speed transmission. I had to pull the tank a couple of weeks ago, then found out it was a hard fuel line that was bad. When I put it together, I used new lines, because 34 year old rubber is not very good. The vent line is much bigger than the fuel or return lines, so I am sure it is on the correct place, but now I can not fill my tank at the pump. If I pull the vent line when the tank is more than 1/2 full, fuel will run out, not sure what that means. To fuel now I use the 12 gallon tank from one of my boats, and transfer. not a very satisfactory situation, Any ideas? I really would rather not pull the tank again, that was not a bunch of fun. Thank you
