Which auto transmission and rear end came in '84 and '87 Dodge D150 short box trucks w/318, auto, 2wd?
Thanks, NYH1.
HemiLonestar, thanks!
Would a A518 overdrive transmission be an easy swap in replacement for either the A727 or A904?
NYH1.
Red Trucker
Yes, A518 is just a small block case 727 with a simple overdrive bolted to it. If I remember correctly it's longer (so need the right or shorter driveshaft) and you might need to check tunnel clearance, though probably not an issue in a truck like it is in the cars. Then you just need to wire up a switch for the OD.
