Just recently bought an '83 B250 conversion van and having a few problems with initially starting the van- once I've been driving during the day it'll start up one shot no problem.
It has a manual choke- the manual says the procedure is to pull the choke out all the way, prime it once and then hold the pedal down while cranking. I usually have to fiddle around priming, cranking and pumping while it's cranking a bunch of times to get it started.
There's gotta be an issue or something I'm not doing right here...otherwise it seems to run fine.
I have little experience with vehicles so any help or suggestions would be greatly appreciated!
