1 - 3 of 3 Posts
Hello. I need some help. 79 360 . Have n spark while cranking but occasionally will fire and even start when you let off engaging the starter with the key before you turn to off position. Have 11.7 volts to new coil while cranking. But no spark to plugs. Replaced ECM , ballast resistor, starter relay, coil and new starter. ??? Thanks.
1 - 3 of 3 Posts
