Hi,
I've got a '79 D200, 360, 2 barrel. It has sat for several years so I flushed the tank, installed new pump and lines and filter, kitted the carb, changed the oil and fired her up. ... no start at first with the old sputter/spit as I let the key off of the crank position but I've been there before. I cleaned all the connections, coil, module, ballast etc. and she fired right up.
Ok .. she's running and smooth and quiet. I let her warm up and adjust the idle mixture .. both adjust nicely ... The problem I have is that on a blip of the throttle I get a puff of black smoke. I checked the accelerator pump nozzle output and they are fine from past experience. Nice thin fine stream not dripping down the throat sides or anything. That leaves the power valve as the culprit. I took the carb apart and checked everything and she's looking proper. If the power valve was open I wouldn't have such a fine idle .. I think that my problem is that the power valve is slamming open on a slight vacuum drop. The carb is a 2245 series (pretty sure ..I think that I remember that #). What do I do to cure it ... or ..
At the wrecking yard I spotted a late 70's (my guess) Volare (or similar) wagon. Nice car with factory mags so just for grins, I open the hood and there is a V-8 (I didn't look to see whether it was a 318 or a 360) but it has a good old Quadrajet on a factory 4 barrel intake. I did some quick research and everywhere I look, this should be a thermoquard ?? Yes? No? .. Did the E58 police package in the late 70's run a quadrajet?? Did anything from the factory in the late 70's run a quadrajet? ... should I just grab the intake and carb and put it on .. thoughts .. and thanks
Summary .. I have a good accelerator pump, not dumping excessively so the power valve is where I think the overly rich condition is coming from when I blip the throttle. The 4 barrel intake and carb in the wrecking yard is a non-feedback early Quadrajet (or as some would say .. no wires) that uses an early manifold heat tube for the choke spring. (not a later electric choke cover). This leads me to beleive that it is a stock factory setup as it also had the factory matching air filter housing (single snorkel). ... try and solve the 2 barrel richness or grab the quadrajet 4 barrel setup??
