1 - 2 of 2 Posts
Going for the patina look on this one. As in... a good excuse to not have to paint it. Technically and mechanically it'll be all new and redone.
It had a tired poor running 318 with a stuck valve, bent pushrods and a lot more issues . The radiator support was rotten. The floor had holes and in general it was abused and poorly maintained.
I built a new 360 for it with some performance upgrades and large vakve 360 heads. Cam intake headers efi etc etc.
Redid the interior. Still have to drop it significantly. Will probably fabricate something...parts are hard to get here (netherlands)
I'll just add some pics
as it came in: (sorry links only, google images won't show the pic in image tags)
https://lh3.googleusercontent.com/K2mbSXYn-OjfmwxS0afQEFOQy-6lufb8bJJjwRlXHkExdhPO8apiUpWvkZ1JoSa6pvnpE6FyxhZrVQ=w1920-h1080-rw-no
https://lh3.googleusercontent.com/DSgseyRG-tfryuaN-sJpFGAI_nJPR-wwy9wLGIN_yPw1W9uDgq4ouExCEZaEjUrakinXhq1rIoU-6A=w1920-h1080-rw-no
piece of junk 318, stuck valve, bent pushrod. Time to pull it and build something new
https://lh3.googleusercontent.com/_4-Q8WfzHETw4i10SUmePD0g0JtuaLkz4im_eo42LPOItX-tvtmrRzxnF6-W4jsbYT1GvxreyzK9mw=w1920-h1080-rw-no
it's a filthy pig anyway, needs some cleaning up
https://lh3.googleusercontent.com/11kwFJqImQ4dNyKdJPiluBLX9qH7pvT5P3kc5Yg8jXuhnvDbAnAtpe4AwM231YsdJO5CTc9J3feHcA=w1920-h1080-rw-no
it's a clean car, no rot, just a little surface rust.
https://lh3.googleusercontent.com/4U65LX7z-QwKG4V7wL8Atn5yANzw6yThOboSIwJ7ZXlCrbulHF5jcpap9jtlffR28vPxU9Wv9CUrzw=w1920-h1080-rw-no
https://lh3.googleusercontent.com/Xwh-jtePYyY9GGEGsjLP5vriYDHX2j1p_J9mCXnx_-22LaqMKo-vph2MfXnEvm7d3HRDNTI6oWgugQ=w1920-h1080-rw-no
https://lh3.googleusercontent.com/O2TqW-tnsb_7R43m1_4SPR7l3CVmxEpIE7Sid7a-T43DlwQMJgVnckcchGrKZxn6U7z_fy4fIpbmvg=w1920-h1080-rw-no
motor pulled
https://lh3.googleusercontent.com/F026OM2K6KrWr0p_3roGIXchUAAHDBYHFEPGhW9hnIHwiIsZVr3qHaic_Oi9VsGbFOjLZf4v2Iluxrc=w1920-h1080-rw-no
radiator support all rotten, pulled it out
https://lh3.googleusercontent.com/lXmPHwcIJSfPbrWfUIvgnH_wP3R20ndd4sGfgT0aSqRZJF4b2Cskyc6cmvo2DD7eZrouVk8HTULOCZc=w1920-h1080-rw-no
https://lh3.googleusercontent.com/RpS6R_4TQ7oJNrSXs1vJjte6p6usBjUHgmjMHBZ7gRknX7gPiZI39aCRj2gIAIAD2WvaxOwehJvZkok=w1920-h1080-rw-no
https://lh3.googleusercontent.com/A7q0OmQg1XBGHpx2PoKsp3TGi09ohLrnQTPxjsD07uCWiBgQyBv7pLE1ljkMzII5zbeY9BQPin8nWbs=w1920-h1080-rw-no
https://lh3.googleusercontent.com/8sCFIGlTWcRVqaijKVBdEMo_zZ8BREbQ74nN2nJia1kncb98eRrmIEAdhi7XknGjmMSkCodh8genVW4=w1920-h1080-rw-no
rear bumper off, time for a rollpan
https://lh3.googleusercontent.com/OvRGk-vdfjSMbGVUQaDQ2gwnZb0fDEQTty9nuzL8JIflgp8PzAeZYMHIkRwSBmnb0-bBII5eqk54vEA=w1920-h1080-rw-no
continuing stripping
https://lh3.googleusercontent.com/VCnCoSmPhXcOIEh92RUCkIVsPIshk9bm1RyMmhcoNVap_K9xOSHhh1msQHi-9ewROsALWKYpT189Xfo=w1920-h1080-rw-no
underside in epoxy rust converter
https://lh3.googleusercontent.com/2IoiySvEhqhN20F2SImHY6cmmCiTWN1OrU_fWyBCAoFGO8v5AtTMu1uebrDlP7cVS339QMtSBQGyTYY=w1920-h1080-rw-no
floor also
https://lh3.googleusercontent.com/UqUGaiaRTSBiKQg_Pf5zsbdam2HTkb_T2dQcV58TLhIfkp7nBDVqh2FC0d6Ony7-tUHIRFnQzRm_5e8=w1920-h1080-rw-no
welded up a ton of pinholes.
https://lh3.googleusercontent.com/j8TypAEgJ0xB89uVjmr4da-sQSYdeF8yehd9zJTGaB5wdVnXeM6MV9YYoQvcvZrfwZKbcWXkYgl1w9Y=w1920-h1080-rw-no
https://lh3.googleusercontent.com/k7fg0KUPkFSmuHVRjanWX1dmjnehMSiTys5hoA_uduqxkDPg5X6nQ5BCuP_LW0BNvhs07JdjIg6zNDc=w1920-h1080-rw-no
before
https://lh3.googleusercontent.com/K6XXmyT1L9IYfz25_7EiOlrbt_sQ4AFrQsUHqBGxPYUyOf2cC7wewetuCtAu7BM5kKx1f2GSD-CMg70=w1920-h1080-rw-no
https://lh3.googleusercontent.com/ZdifmeonToQZoSwzIY-HniBURkt-aIfGq3lFcFk2zceNdlfVcVi7bj-uD__1BiOYeF-M3uQxIOHhr3U=w1920-h1080-rw-no
frame in rust converter
https://lh3.googleusercontent.com/OqaCIkoZKK8MQrNBwBcGhuJAofYMcvpbDe3TpaZxjjnIXz5TYMrV2ev0SP7k74iig9n2PJaoIVLoChE=w1920-h1080-rw-no
time to spray it in stone chip
https://lh3.googleusercontent.com/EBgw27K-ZK2ugOHaF0k-Wi53rEzDeiUoOKbezk_vAJhLX7nqzhrvvcpu4CwdzF4hwRjgeg7acJaOYRo=w1920-h1080-rw-no
https://lh3.googleusercontent.com/vVlgpLDZzPgn0m7T3b80zY6UiSjuSWysLfbpWGdb2VLDQLnpbuOZqIHeHEuEdAmjqM6Lu9ADc3Qs_mc=w1920-h1080-rw-no
https://lh3.googleusercontent.com/aHhAZi0Httk2YLB7P7EcLmZmF2aKENBYVgW5R_7JGL2VWvsqfKZTdA8CsCZuftMj2sk7KBzmL3Ox4mA=w1920-h1080-rw-no
https://lh3.googleusercontent.com/8HcIG727ajG9GK9y8R1MpxfRwLEEEnREOdwrUA68v3dzKm2jN5gU1S7nntyWYHbdBYUoCaQ9csDfmSY=w1920-h1080-rw-no
bought a 360
https://lh3.googleusercontent.com/f-Em58Smvo4FXyY5BLDIKVdGE3GwvYDzYi6hvNxPvp53fTVTOZvb7juAR2LOJJCBOuoqQkEnUkZW6A=w1920-h1080-rw-no
https://lh3.googleusercontent.com/987KnfFBEdo7a0XwSLyJ1VYZfKd5iAgt79p2w9PXZlEY4oBLcnrljh2ab9KgL6x-Rz3edqlHY-V5sw=w1920-h1080-rw-no
needs to be gone through completely.
guess someone cheaped out on oil changes
https://lh3.googleusercontent.com/op6jogjv_E15Bsosnatzr7J03Fo-SW1KS73oxgGTOrijJ3xd-7J2KblXZqGN9QukjpPOJIw4Pftoig=w1920-h1080-rw-no
https://lh3.googleusercontent.com/y70Dep3cUYWD7I7-hbsZ64sLQS663OYj18f4PsIm_KyMHt_Tvf7ktm0mNCwGgsI04_Ok80DtnQ9l8jk=w1920-h1080-rw-no
ugh water corrosion from sitting
https://lh3.googleusercontent.com/AQ-hi5C2HEJxZ33rhJ43_WmkURMtnV-pFoBNYJyRV1QlwuWxoaNQLmBNRyJ-h7Og7b72f0M4_FEioQ=w1920-h1080-rw-no
nice chain
https://lh3.googleusercontent.com/C9phn4R-3rM_Civ_IVhzKHFEvvaBwqCPOJNmFaU89pxVuCWH0mhGd1aqlMamR9Bv554S-6H-TQBjuA=w1920-h1080-rw-no
junk
https://lh3.googleusercontent.com/iNZB1MIbQBXvRV3pH-YmQ_blzNq1rNbzOOQSj837yFIDg1t8LDEcflXPFTNuCorovHKpLhSDp0JalA=w1920-h1080-rw-no
bored and hones the block, checked dimensions. Came out OK
https://lh3.googleusercontent.com/EjNGrTKFYb01hCSIJWvQ-i0wHq_NOB5QLy68xEgmppk7KNpGKdf-8hq19BNEdURO1UB7WL5CDIxVfQ=w1920-h1080-rw-no
https://lh3.googleusercontent.com/G3DfxdozNxptcIEJXUCMPzhvL7D9OPpFYwRAnlU_77l1jlTDGLXoNpT8Katg4gaBNo6AUoAUE6dnJw=w1920-h1080-rw-no
https://lh3.googleusercontent.com/sMT9QHiN96oJEKEijGuCJvKTYxCCYDm-e4ZHSedjgo3-LTzwZTRfZRWBSGdywDI5qnb5Bm4Ms0m6wA=w1920-h1080-rw-no
polished crank
https://lh3.googleusercontent.com/ACTBJ-jOtBRiqgrxNLx6pImeEtrz5nzu_ORtysRgfhhysGgh3ibx1HLzj0Fq9PiQUpoq1y87ceqA3w=w1920-h1080-rw-no
timing cover was cracked, removed the broken piece, ground it down, tig welded together.
https://lh3.googleusercontent.com/4fla6h5_kN08HnQNBGweQG0t3Z-MWFyA0VFXOkoRAaUQ5q3sJnE8d-6jzRzoWuPsSOFqOcRlO_skDg=w1920-h1080-rw-no
https://lh3.googleusercontent.com/4ot_kpzR4ntX-MH0eKwkU8sKzqpPBMcAICqV9ktVgfX-bSR28naliq2zuHYZXosUdggNdTuCy0RP7g=w1920-h1080-rw-no
https://lh3.googleusercontent.com/EG23El-o_2xAwX4quBUXM4DHw-9CK_fQB_DNxN0SNkTkl-8poQZExys1BaEowmX1eIhA4ARhMIdChA=w1920-h1080-rw-no
sandblasted cover
https://lh3.googleusercontent.com/Ngbf4GmAQ5tLPaoEV6n7hm86UGV1I_UOx6_e05h3KGE33Dm63sPEVPVUIeD7fMx8IDCjgvPTRCg15w=w1920-h1080-rw-no
more corrosion around water ports, time to weld that up
https://lh3.googleusercontent.com/sOwfn1YwFB8nKWI5pjZz15mKE8Bopct8RuXGSFtNiK57bxj828I2W8tjQItIs8786kTY437HC0Tj2g=w1920-h1080-rw-no
https://lh3.googleusercontent.com/HBKdZCx3ccgGtp_yPT9rUY0LbJy6lvlSZkr2nEQG4qfxJW3gP_tIQTUUmHO-O0KWlrT-XFjlcd-Pow=w1920-h1080-rw-no
painted, new plugs and fitting rings
https://lh3.googleusercontent.com/csHk3UaNQpmytW6_-R0KlztF2xsFTVTL-uryZxf5JScVrQgS1dN1s95c_j83HkR6KDiFOYCDVFZeiXQ=w1920-h1080-rw-no
https://lh3.googleusercontent.com/woI-A9HTcIpnPcsjkKH1i6R59GLEA9MWOZLKmXncNMqCRHe6N33d6Ap0RqHJkIEayzp9ADuJB6uGTX8=w1920-h1080-rw-no
crank in, checking end play
https://lh3.googleusercontent.com/NmMOrlVenbYwQ0FHRuc8hhfeLA6Wa8ZsoKUkdn0EnZ6EXrieGWMTs_098L6VoIqOxiW251tnqSAe93Q=w1920-h1080-rw-no
new chain and a tensioner from a v6
https://lh3.googleusercontent.com/3stpsmieghyjb-hsvFliNU0alVgM6eGsxhSSmia0J3fTqR-lsBRwHQYYAXIHKAKyx5xyWbS12I81t1c=w1920-h1080-rw-no
all clearances checked, rotating assy assembled
https://lh3.googleusercontent.com/EobJV9IRse1yK9zgyoL7-RqopQimLg6m95fCzNJ-MFEf0-N-3QUymozrTQcloEsdBvATifaTAjSDIHI=w1920-h1080-rw-no
new pump, powdercoated pan
https://lh3.googleusercontent.com/ydARoQn_kZxNA0VDdCyGVzJhXxB3BU7IiFxpc8f663dQopUZoV9O_jpp5SV3r6sQ3czF7QwzLIU0Xus=w1920-h1080-rw-no
finding tdc
https://lh3.googleusercontent.com/ZZ6tVenXlC13-_gWvNQy6iUFMPJ1vhfWL5_iq-2iyVlw8xYOldgeS8qdZDzLp4CaMkEtztiuNvGaNZg=w1920-h1080-rw-no
https://lh3.googleusercontent.com/iNUgZD0onwbC08xmTVtDIi-QEsJeQDNfwfgNZh_3DwILr7hG4QPlpYn2cTpLi_MBfCz8jzqjBXPArho=w1920-h1080-rw-no
https://lh3.googleusercontent.com/NfzsXCa6vc6SZTsrruS7rsnXFn0f9EgmQoarTSzRYQm5bW08iPi0Q92Xb7J-HJaHObcHSPEEioIt-cw=w1920-h1080-rw-no
https://lh3.googleusercontent.com/Diq7TFjLw0C5yNzUzzUISfhQdNhgO0aC4rrUNb5rjYYT0_b8U31zuAhPOBqBsjY1GR_Z4Kn_9s9l6tU=w1920-h1080-rw-no
https://lh3.googleusercontent.com/3_LIuHKBzmAZl6mHvR6t2irS6MifT9CI4aUMqiWyk3KGs1mG0WyvB5LV49SEh-wdYakj-x7R4nDE2_k=w1920-h1080-rw-no
rebuilt heads, these are 360 heads with bigger valves and a little bowl work. Had aluminium hads but they are without valves. Maybe sometime later. Didn't feel like pulling it apart again
https://lh3.googleusercontent.com/1YnZsy87Gx75kdJV-5i0viWDFMa2UMTn7oxcQL3LcRuEBIDyYqEXAUjrW7eEXrtRRTCBG7D3vMM-Zmc=w1920-h1080-rw-no
https://lh3.googleusercontent.com/3Umvbzd93UoNGOU9H8ShfVDNb9Bq20uf7g4_rAFacZSGyXCawI2C6yq0dcTPRg1K-6qScOmUUeAI-ss=w1920-h1080-rw-no
done, has injection on it
https://lh3.googleusercontent.com/uXOgKsnnEdd2oEofBdhPLdQfxf5VC2sefdHcPQpi-wm1nIIex_wefQhYA_b-Ceh7B7rpqz2WlR_ZST0=w1920-h1080-rw-no
https://lh3.googleusercontent.com/iQZqR7lKwNY54NvO-TBKK2WnSHoTIHUuiO926CnxA3uGmBY5rVEjhydgnSW-KbJPWPuPpbjWoAFJUJI=w1920-h1080-rw-no
https://lh3.googleusercontent.com/l3CVcmZDhXi68eKIMuIM4jU8DCBDyR5qmDKdZpa7GSIdmYBofsFcNONy8a0_k8_rLr6lTh9fzS8gUqY=w1920-h1080-rw-no
map sensor etc installed
https://lh3.googleusercontent.com/MChlCsv5VZ9tp5hIE4Sp7W0fYgAatmJ3PdLEA9WksJKbTrSyR8SgnHl9eAmGa58PGmjEUZSfqkrhG88=w1920-h1080-rw-no
time to bolt up the tranny and drop it in
https://lh3.googleusercontent.com/tjEn2D8A8qH120ddFx000YFDJNmv5G8I_9fgYZdEzDDtWZBL1r6etG7k_gJhLEtIgbBxbiCW5GCE484=w1920-h1080-rw-no
https://lh3.googleusercontent.com/jz_vcc6XbqZPK-qzf0mgGRmRg42KMHTOEoTgNc9MptxirORDzV-A_CtFkGmRm__0HppNp90y8zKYOD8=w1920-h1080-rw-no
ahh..much better
https://lh3.googleusercontent.com/B5Y8LtXIu3Wh0MT7cKI6ZgIgcPKbHJ0raEjZxpZJ4PpDDGTChY4l88HyCcBQQiaGUXtSExlG2BvRFWw=w1920-h1080-rw-no
https://lh3.googleusercontent.com/ksqi7MEVJUYOwncxIEm8g0ORF1SeOJdeiSo0Q1yBq6H6GP9GyZq8E0dIgh7KEK5RJZphcQEk7ZEQDtI=w1920-h1080-rw-no
everything that came off was zinc plated or powdercoated
new rad support
https://lh3.googleusercontent.com/bjfioJPDXSsjBPe1I5ILko4E60Fb30TeC3mGQBrTPrVyR234iT8cxJSNpv4sbds5nZch2Z_GaL61VEQ=w1920-h1080-rw-no
https://lh3.googleusercontent.com/E6UA7Q2tTogz6gMqgzXBJI9w44HNoWiHI5dkXGj8jBSmX7uP4H8St5674dhS9V_ePKS9uqNiffZAOjE=w1920-h1080-rw-no
fresh carpet, weatherstrip, dash cluster (repaired), new heater core
https://lh3.googleusercontent.com/zk4SYR359PB2Ds3qGCc8ZWeCGW7U1Ahkiuc2pRa-EmeplyNDLcwuof4k557IJcQvV1M6eK67ZxTpRDM=w1920-h1080-rw-no
new dash top, custom mixed metallic paint to match (old stuiff was cracked etc)
https://lh3.googleusercontent.com/SY6IOcinVcsPmmpjijiqPN1hxdK6K3Ow7_16vArClwx55sJliqpTYuBOjANiNVJxqb42ERL6m3rlYDk=w1920-h1080-rw-no
https://lh3.googleusercontent.com/fl8ZG_FowNmVccyOqUvOPKWh59mo8BtNkjiDy6JR_VDm6RspJnjWr8yaMg4yo6dFtG2gbeER9qZGwtg=w1920-h1080-rw-no
time to fit this univerfsal cross flow radiator
https://lh3.googleusercontent.com/wtuLRLmAxt135ynOJkz1JG5mXRa5Y4q1VV136O4dPOqE_qzC-Zqd9WhbmlE9XkCzjimdLgFD8ZmpBPI=w1920-h1080-rw-no
Decided this was how I was going to do it... tig weld some mounting plates reusing oem holes in the support
https://lh3.googleusercontent.com/3txAdC_B7cgoluntD7qmCg2cPOuyI-rx7tp2e8C6VC2xPJCHAnjHWxRx_Kis38bFDYZHlJNxLP-DjwI=w1920-h1080-rw-no
https://lh3.googleusercontent.com/hc0sav-AnnBthlZzHYZogh6pc6MjWkdydaZwjZkMmFLNcIuqmcv9ui1wpHTLG3AUrm_6PmBcB7v9Y7c=w1920-h1080-rw-no
https://lh3.googleusercontent.com/Gd2fbOwH485vKbELtJIN7Q9wDqm5SlqyTPE9gsSoU4KLCPHu56su7gtnqDJkM2zvGfzB8w44TlWMV7k=w1920-h1080-rw-no
https://lh3.googleusercontent.com/ek4l6o0vcTLtDroMBf81zf5SBOlVFUNwsejjNzU5iDMmscif_aZDTHiKjtW9Y2S11EDYKRjUysktDmM=w1920-h1080-rw-no
https://lh3.googleusercontent.com/xYh2E3LOFx0rELAPkl7S-ln4tF2E2DeSlBGzRQV_syQbuPrtSZQOrSk22D7sHfVlKWer8Fw0MC-TKiE=w1920-h1080-rw-no
https://lh3.googleusercontent.com/bi76pW_P9SVtcJeF9PxbmPcYsNZ73nB9x1oHNeolHyIL-x1fV2Y8FvjBx97veqUsM4uBb-HGWmZPU3Y=w1920-h1080-rw-no
now I had to fabricate a surge tank. The mechanical pump will pump from tank to the surge tank top inlet. The burp line from the top will return to the tank. the EFI fuel pump will feed from the bottom and the EFI pressure regulator return returns to the tank at fuel level
I have used this type of system on my 83 chevy stepside also (it's got a supercharged 355)
filler cap and bottom feed
https://lh3.googleusercontent.com/p6A8gFYSYZHQ9ox3smGV3bzhmD-YhyS5QRrCFvDpeQaZ7VGNtAd2Ylw_0uKXibEEoXW87p-fbR5dubs=w1920-h1080-rw-no
tank has plenty of volume
https://lh3.googleusercontent.com/oKJ7hkw0lQLlsJkOlgdJk8V45mtrF029z2D1OHrpMSyFS_f2m2Sap39IXeQ2nECGpJ3-EzZ0K3EjbH0=w1920-h1080-rw-no
https://lh3.googleusercontent.com/r2_5-aelWBFwPMcz22kiWC-dIW7KVEuFEo3HL9YbHy9ZazGizpYf6AYqRaIA2xENxw7il3NMdwyUmFI=w1920-h1080-rw-no
https://lh3.googleusercontent.com/oyIFFXpsQzuay4nTLBrp7qz4d1xgIQSHE8U7ejzdFGzdZqv_8n448Q1TIoPPZhpJAgPGsNoQT6BcE1E=w1920-h1080-rw-no
https://lh3.googleusercontent.com/pllXf_B8k8FaFQuIJLn12N2LbtqLwN8OJZo99PfsGrrvugc7Ve4tphB6Wgt5fqTESFmW3VumEas67pQ=w1920-h1080-rw-no
complete with pump mount
https://lh3.googleusercontent.com/X2RUfAjkeNgRZHXJluLEWRdBXNe4e6E5yLzJuAEgfJpwuESdo4U0xXmVDobf0agrzREGymo1MP5Tm44=w1920-h1080-rw-no
it's mounted on the pass side front. That's a nice cool area
wiring has also been checked , repaired and modified for non stock parts
https://lh3.googleusercontent.com/h9aUaVzGNb5UFHXMJiS1dBNPncU_k5V0VwMEvdcaT6mYsuOHfQIUYrmTTnEC96dLlPFuFxg2VMtwVMw=w1920-h1080-rw-no
1 - 2 of 2 Posts
