my friend have 2- 727 trans. The bell housing numbers are 433 and 432-5. The 433 i found that it cam out of a 1971 road runner 383. The other one I can't find any info on it. I was going to buy the other one but can't find if its small block or big block.
Red Trucker
Compare the bellhousing to the one you know came out of the big block car. Same size = it's another big block trans, smaller = small block trans.
When replacing the rear main seal on a LA 360 do you have to remove the oil pan and oil pump. Is it a 2 piece or one piece seal.
Red Trucker
Both and two piece. Couldn't be one piece anyway, how would you get it around the back of the crank without stretching it lol?
Discussion Starter #5
Also I keep getting water coming inside of my cab on both sides of the driver and passenger side kick panel. I had the wind shield replace already. Only when it rain
Discussion Starter #7
How do you wire up a msd ignition to my la 360. I want to get ride of the oem ignition ballast resistor, ignition coil module. I want to wire up a msd and install a msd distributor. Do anyone have a wiring schematic or how to install this setup
