1 - 16 of 16 Posts
Inertia ROCKS!!!!
Okay I've been running 13.6-13.7ish at WOT with my truck. Can't seem to do much more with the PSC-1 so I was going to toss in the 6.1 injectors I have. My question is what should I expect as far as a change in my WOT AFR's? one point? Hopefully no more....
Well since your motor is going to run much cooler you could probably add some more timing if you had a tuner.
But i would quess low 12s,and i bet your going to have a bit more power because of it.
Hemi2nV
about 2 points. then you wont have to add as much fuel.
Inertia ROCKS!!!!
Get A Diablo!
Sorry Luke I have zero faith in that tuner, maybe in a year when it's a more stable product. By the way these 6.1 injectors are the one's I bought from you a while back.
Had 392.. Now.. LS2 GTO!!
ahhh.. i wasnt sure if you bought then or not.. my bad..
ya i think i farted in the box that had those in it..
now i rememeber..
put them in and see what happens cant hurt.. maybe something like a fuel regulator to insure you dont pull to much fuel and say bye bye tranny
Inertia ROCKS!!!!
now i rememeber..
I was thinking the same thing about the fuel regulator. Yeah HAHA about the fart thing....animal.
Sam, Get larger than 6.1 injector's and tune your a/f's with a fuel pressure regulator or think about an iEMS3 for tuning.
Inertia ROCKS!!!!
Discussion Starter · #11 ·
If i got the 268 cam could i get the 6.1 i injectors instead of the psc-1 to keep things ideal?IF so i will be hitting up a junk yard...
Absolutely not, with just a cam you'll be fine with stock injectors. If you just toss in 6.1 injectors you'll be way rich, and probably throwing all sorts of codes. Get yourself a wideband and some sort of tuner.
just man up and try a diablo i am sure someone will let you borrow one of stu will let you borrow one..
i know you will be very happy dude..
Inertia ROCKS!!!!
Discussion Starter · #13 ·
No thanks, I've seen first hand on two vehicles what Diablo is capable of, not to mention all the horror stories you hear on the forums.....
yeh my baby needs abottle
i just got my diablo. and i love it! for now... i would just keep the TC stock.
Lots of different opinions out there on this issue. With the psc and the 6.1L injectors I was around a 12.7 at WOT.
I'm working on some tuning with Diablo but with the weather around here its been kind of a slow process.
1 - 16 of 16 Posts
