1 - 20 of 26 Posts
OK I got 6.1 cam on it's way and hope to install this weekend.I have read alot
about the install but have a few questions. I have cam lube and silicone gasket in the tube.Will I need any other gaskets,and are there any torque
specs for bolts I need to know about?
Thanks..
Inertia ROCKS!!!!
You need a factory manual for all the torque specs and such. Click here and download the manual. You won't need any gaskets, but you will need an impact to remove the crank bolt and cam bolt. Harbor freight has a descent electric impact that works great for $50, I bought it at their store for $40. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=45252 I learned from 03ramit1 to use a little RTV where the block, pan, and front cover meet. I also used a little assembly lube on the crank pully when I reinstalled it. Good luck!!
Inertia ROCKS!!!!
03ramit1 said:
ill pm you my phone # and you can call me w/ anything you might need help w/
Definitely call him, I did a bunch and he was a HUGE help!!
All Around Great Guy
Now you got me thinking saw and i want to go with the 210 or 260. Which has a higher lsa? Does anyone have specs for both side by side?
ever do this when you order a part for your truck?
6:29 AM
Departed FedEx location
HUTCHINS, TX
1:41 AM
Arrived at FedEx location
HUTCHINS, TX
Oct 16, 2006 8:56 PM
Left origin
BRYAN, TX
6:25 PM
BRYAN, TX
6:08 PM
Package data transmitted to FedEx
MADISONVILLE, TX
4:56 PM
Picked up
BRYAN, TX
LOL!!!!!!
6:29 AM
HUTCHINS, TX
1:41 AM
HUTCHINS, TX
Left origin
BRYAN, TX
6:25 PM
BRYAN, TX
6:08 PM
MADISONVILLE, TX
4:56 PM
Picked up
BRYAN, TX
LOL!!!!!!
You might be a Dodgetalk-aholic if......... :D
Inertia ROCKS!!!!
These are the specs I have for the 6.1, 210, and 260. The specs for the 210/260 are correct, but I'm not 100% sure how accurate the 6.1 specs are....
AC Grind 6.1
0.541"/0.528" lift
208/211 duration
at 0.050" lift 114 degree LSA
XFI 260 Hemi
208/212-522/525 LSA 113
KRC 210 Hemi
210/214-523/526 LSA 112
Inertia ROCKS!!!!
According to those specs I really don't see much any improvement over the 6.1. especially the 260...BUT like I said I'm not 100% sure those 6.1 specs are correct.
I wish a Harbor Freight was near me. :( I went to my first one when we installed Freds Cam. Nearest one to me is like 1 hr away.
KB
AC Grind 6.1
0.541"/0.528" lift
208/211 duration
XFI 260 Hemi
KRC 210 Hemi
The 6.1 specs are impressive... Lift is great and duration is decent but it is the lobe seperation angle that is killing it. The 210, with a tighter lsa will have considerably more power and will also reduce vacuum levels as opposed to the 6.1
HEMI way or no way
well my 6.1 is here tomorrow....when will i install? Well not sure yet but if sawcut is up for it we might do it sooner than expected
well i say do it sometime this weekend!!
ramcrazy said:
6.1 FROM ART KENDRICK
Oct 18, 2006 10:02 AM
Delivered
Winterset, IA
Left at front door.
Install this weekend for sure, :D :D
sweet!! let us know how it goes!!
Inertia ROCKS!!!!
Lets do it Sunday....be here at 7:00 AM. Bring your cam, crank bolt, enough coolant, bag of floor dry, and I'll get the puller Saturday night from Autozone.
I think I already have everything else from when we did mine.
thata kid!! way to take charge and get him going!! lol
Inertia ROCKS!!!!
You can haul yo azz down and we'll install your too!!! :D :rck:
1 - 20 of 26 Posts
