Just an FYI for those who don’t already know. If you have an early model 5.7 with the weak dual spring heads(53021616BA- ‘06 Charger) like me, you can upgrade to the stronger single spring 2009 head(53021616DD), I got mine used off of eBay for $300 and did a Valve grind and seals BUT... (here’s the kicker) the ‘09 heads use LONGER PUSH RODS! Get the ‘09 push rods...$27.00 per side at the dealer. I committed the Mechanics Mortal Sin of just ASSUMING they were the same... Silly Me! Not a pleasant sound for any Mechanic! So... Those of you who don’t already know...There Ya are!
P.S... Once the new P-Rods were in she purrs like a kitten!
Red Trucker
That's cute LMAO
People have known about this since 2009, BUT....you left out quite a few things lol (which you may or may not realize), like:
1. Eagle (09+) heads have a smaller combustion chamber than the 03-08 head. If you bolted on an eagle head with a stock head gasket you just jumped your compression ratio from 9.6:1 to just shy of 12:1
2. As you discovered, longer valves that require longer pushrods. They also require different valve covers (hope you didn't reuse yours). 09+ 5.7 and 6.4 valve covers are different to provide clearance for those longer valves.
3. Exhaust port shape is different (03-08 is round, 09+5.7, 6.1 6.2 & 6.4 have D port), you have some pretty healthy port mismatch if you used your stock exhaust manifolds.
4. Intake port mismatch - intake ports are different as well
5. What did you do with your EGR? Eagle heads do not have a provision for EGR, which the earlier engines (with the exception of the 2003) all have
Hmmmm.... Well... Not ALL people know about this and as a retired Euro Car Mech of 42 years I didn’t know, that’s why I posted it stating it is for those who DONT know NOT for folks like you who DO know and you’re right about the intake ports,the ‘09 Ports are larger but I had no mismatch issues. BUT.... the exhaust ports are the same....I checked. The head gasket is identical.... I got both and compared them. As far as the compression ratio, I have no idea what you’re talking about, I replaced #1 piston so I took compression readings after I got the push rod issue straightened out and they ranged from a low of 128psi to 134psi sorry but that is nowhere near what a 12:1 compression ratio reading would be. The valve covers are identical and have no issues with them and as far as the EGR is concerned... its the same, it all bolted up with no problems. Anyway that’s my experience with my “06 Charger Daytona as far as other Dodge models go... I don’t know, I still mainly play around with the European stuff so there ya are.
Red Trucker
Didn't say ALL people
Now I just think you're a moron lol...this is why:
03-08 hemi head exhaust port
09+ 5.7. 6.1, 6.2, 6.4 exhaust port
Tell me how there's no difference again Mr Euro mechanic...?
Also:
Early combustion chamber
Later combustion chamber
Early valve cover
Later valve cover
Also 09 & later heads do not have EGR nor does the intake manifold have provision for it as that function was handled by the VVT. Here is a 2010 5.7 from a car; tell me where the EGR tube is? Oh, you can't because it's not there.
To summarize: you got replacement heads for an 04-08 hemi and are either mistaken, been lied to or a retard.
