1 - 3 of 3 Posts
2006 Mega cab 4 x 4 with 5.7l HEMI.
I was changing the engine oil and filter on it normal service interval. When I pulled the plug on the oil, it sound hitting the pan was different and then changed. I know water (antifreeze) is heavier then oil so I caught the last out of the container I was using and poured it into a glass jar. I left it over the weekend and found antifreeze in the bottom. Any ideas on were to go next? I also found that rust on the fill cap. I hope thats ok. I am thinking that the center head ( intake manifold ) is the problem. Please any info!
Tricked out Ram
usually you leak water in the oil from a bad head gasket. I guess it could be in the intake gaskets or even the timing cover leaking.
1 - 3 of 3 Posts
