1 - 2 of 2 Posts
I want to get a 3.5" fabtech spindles for the front of my truck then put on daystar 2" coil spacers and get a block for the rear.
I want my front to sit a little higher in the front. Now if i didnt put a block on the rear it would sit 3.5" higher in the front.
How much are 1" and 1.5" block kits for the rear? What block kits for the rear are good? i also have airbags in the rear and i could pump them up a bit to raise it a little.
Do you think this set-up would be a decent set-up or cheap and would it also look good with 35" tires?
Discussion Starter · #2 ·
come on someone has some info or tips.
Im also thinking of getting the Doetsch 5" lift and maybe getting a 1" or 1.5" spacer for the front to get the front close to level or a bit higher then the rear. Depending on how the lift is Doetsch might already level it out.
1 - 2 of 2 Posts
