1 - 2 of 2 Posts
Does anyone know if a 5.2L engine from a 99 Dakota 4x4 will fit into and bolt up with little issue into a 94 Dakota?
Little, yes.
You may have to swap sensors (shucks, I'd do that ANYWAY due to the age of a motor from a 1999 anything!)
Since they had dropped EGR for 1994, and they had switched to 24lb injectors, which stayed the same, then it should be OK.
(There was a tone ring swap during the run; but I THINK that was for 2001. If in doubt, recycle the old flex plate and torque converter.)
RwP
1 - 2 of 2 Posts
