1 - 9 of 9 Posts
i have a 99 5.2L "D" when i put it into 4 wheel drive, there is a whining noise coming from the front axle area, and it won't go back into 2 wheel drive unless i stop and shut it off. Anyone have any ideas? Thanks in advance
doesn't matter when/where
Todd O
What yellow is asking is are you doing it on dry pavement or any type of hard surface. If you are 4wd is only for slippery type situations like sand, mud, snow, ice or a really wet pavement
Discussion Starter #5
usually in rain or mud, the last time i used it i was in a huge ditch and needed to get the truck out of it. i don't use it on dry pavement.
Discussion Starter #6
does ANYONE know what this could be? my girl drives it and shes pregnant. i dont want her stranded somewhere. thank you
My '02 4.7 does the same thing. I will eventually go back into 2wd though, but the noise is really annoying.
i got under it and cleaned the 10 pounds of dried mud out from around the transfer case, and all the plugs and stuff now it works perfect.
1 - 9 of 9 Posts
