Specifically, is a 46rh that was equipped in a 1993-1995 Grand Cherokee 4x4 different from a 46rh that would be found in a Ram 1500 4x4 from 1994-1995? I know that the ouput shaft on each overdrive unit has 23 splines, but is the length the same on both? I could not find an answer to this question by searching. I apologize if this has been asked before, and I was unable to locate it.
Also, does anyone happen to have a list of parts that are different between the 2wd and 4x4 46rh tail housings? I know that the output shaft is different, does anyone know what other parts will not interchange between the two?
