4WD "101" question - use brakes to increase traction?
2K views 8 replies 8 participants last post by  Ramhemi03
#1 ·
If a 4x4 with OPEN differentials is stuck in the mud, with 1 tire on each axle spinning the other not, would applying the brakes send power to the slipping wheels?
In other words, can you create an LSD effect by applying the brakes? Or does the "brake trick" only work if you have LSD axles (Torsen, etc.)?
#2 ·
Brake-Throttle Modulation (BTM) only works on certain types of LSDs (Torsen, etc). It's the primary method for maintaining traction in the military HMMWV (which uses Torsen diffs), and will allow a skilled driver to get over/through obstacles that would usually require a locker. Not gonna happen with an open diff.
Save
#3 ·
Yep. Did some more research here. An open diff always applies equal torque to both axle shafts. Applying the brakes does nothing but add to the axle load - equally. It will not force more torque to the traction wheel.
#5 ·
You will need individual e-brake for the rear wheels, if one is spinning, use the e-brake for that wheel, so power can be sent to the other wheel.
Save
#6 ·
Yes you can, have done it a bunch times, it makes the traction differance less as far as the diff is concerned and helps put power to the ground. 4low with really pushing hard on the peddle can really help you climb/get out of situations.
Save
#7 ·
pull and hold the park brake release and slowly apply the parking brake. this will force power to the wheel with traction. takes some practice but has worked for me many times.
Save
