Premium Member
I am needing a set of 16 plugs for my Hemi, manual shows NGK LZFR5C–11. How much for a set shipped to 74012?
Hey man, unfortunately, that plug series isn't available to the aftermarket yet. You're stuck having to purchase it from the dealer :(
If you're willing to switch brands, Denso has a couple of options:
PKH16TT is the new TT Platinum Plug - its an economical fine wire
FK16HQR-11 is a long life iridium
FK16HR-11 is a long life platinum/iridium with dual fine tips
SK16HR11 is a long life platinum/iridium
IKH16 is Denso's standard iridium power series
Shipping for 16 plugs will probably run you around $11 to that zip.
Use coupon code D0PLG10DTC through the end of the month for 10% your plugs!
Premium Member
Well that just sucks! Do you have anything in NGK that is 1 heat range colder maybe?
