48RE strenght, and frame question
664 Views 6 Replies 3 Participants Last post by  03cumminsmtz
hey, im curious, i have the 250 cummins infront of a 48re trans, is this the same trans used on the big 610 motors? how much power can i safely run through this transmission before i have to think about upgrades? i am running 35" tires with the 3.73 gear ratio.
also, on another note. is there anything in our frames, like wires, or lines or anything at all? im workin on a little bit of a custom project, that would involve running a winch line through the entire frame rail, as long as i wouldnt cut through anything.. thanks
1 - 7 of 7 Posts
The 48RE is the replacement for the 47RE and is the same in all Cummins motors. If you have a 48RE with your California smog motor then you have a late build 03 and all the trannys were the same.
what is different between my motor and a regular 305 horse? is the injection pump/lift pump the same? different settings?
I could be wrong but I think the 305 HP was the first with the common rail injection and was considered the "HO" version.
yeah, i thought so too, my neighbour has a 03 305 1 ton and it looks identical, except for the ratings.. im just curious what the difference is, and what the difference might be if we would run the same chip or something
Here is the break down for the CR's just incase you haven't seen it yet.
2003 S.O. Federal Emissions: 250HP/460lb.ft. Available with NV4500 or 47RE
2003 S.O. Calif. Emissions: 235HP/460lb.ft. Available with NV4500 or 47RE
2003 H.O. Federal Emissions: 305HP/555lb.ft. Only available with NV5600
2003.5 The 47RE was replaced by the 48RE automatic transmission and available with the H.O.
2004 S.O. Calif. Emissions: 235HP/460lb.ft. Available with NV4500 or 48RE
2004 H.O. Federal Emissions: 305HP/555lb.ft. Available with either NV5600 or 48RE
2004.5 (50 state legal) 325HP/600lb.ft. Available with either the 48RE or NV5600
2005 (50 state legal) 325HP/610lb.ft. Available with either the 48RE or NV5600
2005.5 The NV5600 replaced with the G56 6spd manual gearbox.
See less See more
well i just got word its time for a rebuild.. or something. shit. need somethin else
1 - 7 of 7 Posts
