Thanks tactransman. The TV cable adjustment fixed the passing gear problem and the shifts are a little firmer, but the OD is still out. Maybe I should add that my Dakota is an '01 and the replacement transmission is from a previous generation. I had to drill and tap the housing to accommodate my safety/gear position switch. I also swapped the lever/cam to compliment the switch. I will have to adjust the shim on the switch as my dash gauge indicates a gear lower than actual. From what I've read, I see no indication that the gear position signal relates to the OD function. Your thoughts...
