1st issue...At slow speeds trans can't decide if it wants 1st or 2nd gear. It goes back n forth.
2nd issue...When I hammer it, trans is not shifting into 2nd, bounces off limiter and I have to lift for it to shift. I'v adjusted tv with no results. All this seems to have appeared all of a sudden. 2nd to 3rd gear is great. Changed fluid about 3000 mile ago and adjusted bands.
Also, I just remembered something else, when I put it into park and foot not on brake I then shut off the engine it rolls back a little like takes the tension off. Really weird.
Recently had B&G reprogram the PCM for a second time due to injectors being changed.
