1 - 13 of 13 Posts
12.40 @ 105.92
which gears are gonna be clear winner in the 1/4 mile on two identically modded trucks. I know 4.56 will be faster in the 1/8th but I want to know about the 1/4. which should I get for my truck? any input is greatly appreciated :rck:
If you are planning on headers, cam, heads and tq converter then I would do the 4.56 gears. They will get you into the powerband a little quicker and with you being a 4x4, you likely are running a taller tire than most of us 2wd guys. My truck came with 3.55's and I've changed them from 4.10 to 4.56 and now 4.88's. I like the 4.88's the best for my mods. Never fear the gear.... except maybe when gas is over $3.00 a gallon.
Tached real high on the highway eh? I was thinking of having 4.56s installed in my 2500 with stock 265 70 R17s for towing our 5th wheel. I calculate about 2400rpm in 4th gear .75 O/D at 70mph. This about what you saw? Was it objectionable with gear noise or driveshaft whurrrr?
Tank Mech
dale3fan3 said:
You have 3.55 and if your not going to 35s or better in tires 4.10 would be a nice jump. I rode in a 2wd with 4.56 and 265 70 17 tires and I will say that thing took off!! It also tached real high on the highway because its only a about 31" tire
I wonder who THAT was?? :D
Tank Mech
It's a 1500 (dunno if the different trannies have different end ratios). But with the stock 17's I'm running a shade over 30". I may need to recheck my diameter and double check it with the SC, but right now 70MPH nets me right around three grand on the tach. I'm always a few MPH off from the police radar trailers on the side of the highway. So maybe being off on tire height, coupled with the MPH being a little off, and having shorter tires can be fixed relatively easy. I just need the revs to come down a couple hundred....
Tank Mech
Just did, lol.... :D
Tank Mech
Oh, and I just laid two heavy strips on a road behind work today. A good thirty to thirty-five feet long.... from a 4.7!!!
Time for drag radials....for the street? :D
12.40 @ 105.92
Discussion Starter #13
thanks guys for the input, however my tires measure 31.75 so which is better 4.10 or 4.56? and who is clear winner in 1/4??
1 - 13 of 13 Posts
