LOL that would not be even a close show down..... Im not even going to get into it...LOL I can already see where this could lead.
Im sure there are kits available as the 4.7L has been around for a few years. I know FAST MAN has built a few Turbo 4.7L great with success. As for how much power it would produce... It all depends on how much you want to make... you can only go so far on the stock parts. The top ring land is real close to the crown and will not take kindly to too much heat... so thats limiting you. BUT if you go to a NEW forged Piston you will be able to LOWER your CR to make better use of the turbo/BOOST. With the right combo you could easily make 400+HP with a 4.7L. Sounds like fun. I would get the heads ported with 212 cams... to make use of the Turbo...
SPEED SAFE, AIR RAM
