I've replaced the tstat (twice), flushed the coolant, bled the air, replaced the radiator cap, replaced the fan clutch, hosed out the radiator and a/c condenser grills...what else can I do???
It only runs hot while driving in hot (85+) weather. The hotter the weather the hotter it runs, and using the a/c makes it overheat.
I'm thinking my next step is to remove the a/c condenser and really give it a good cleaning (i.e. hose it out backwards), or replace it all together. Is there anything I need to know about removing the a/c lines? Will I need to replace the refrigerant when I'm done? (I have zero experience with a/c systems)
Anything else I should try first?
(2000 Durango, 4x4, 4.7L, no mods)
