We need a fix for this problem. Let me tell you my story. We have the exact problem on a 2002 4.7 truck. The problem started out as a headgasket leak on #2. The heads were pulled, slightly milled and put back together and we have this problem with it setting all the coil codes. The valve covers were pulled and the cam timing checked a second time. We sent the truck to the dealer thinking it could be a pcm problem of some sort. The dealer replaced the pcm, and all the coils and the problem is still there. The dealer gave up on fixing the problem and sent it back to us and we are lost on what to do. I sent the first poster a pm to see if he ever found a fix.
