The 2.25" you have read is in reguards to "True Duels"Nathan K said:I just got a Magnaflow 3" SI/ 2.5" DO, going on a bone stock 4.7l. Is there any reason not to run 2.5" DO on my 4.7. If so, why? Ive read to stick with 2.25" on a 4.7, can someone give me a detailed explanation as to why?
Well in your statment you just proved they at least "SOME PEOPLE" know more than you! :thatfunnyadamsredlines said:Because some people think they know everything there is to know about the 4.7....
If its a SI/DO, the DO doesnt really matter what size as much as the "in" part does.
You'll be fine man
Unfortunately 2.5" duals even on a "CAT BACK" will not be the best option for your 4.7L... Unlike "SOME PEOPLE" I will offer an explanation along with my statement.Nathan K said:I just got a Magnaflow 3" SI/ 2.5" DO, going on a bone stock 4.7l. Is there any reason not to run 2.5" DO on my 4.7. If so, why? Ive read to stick with 2.25" on a 4.7, can someone give me a detailed explanation as to why?
LOL... Yeah right dude, you know exactly what you where "IMPLYING"... Hows the truck running? Hopefully SCT will have it completed soon so you can lose some of your bitterness. Im sure with your list of mods you should be running some impressive times.adamsredlines said:I, unlike SOMEONE on here, dont claim to be the know-all, god given gift to the 4.7 world. My technical experience with these engines is very limited, I've never claimed otherwise. I've never played up my experience with them trying to make others think I've torn these down and know whats going on inside them like SOMEONE.
And why take offense to a general statement, unless you think its YOU who thinks they know all...surely thats not the case?
Your right, it does... if you cant GRASP the theory of opporation it does help to be able to understand the subject enough to brake it down to a level that can be understood by someone who does NOT understand the threory of opperation...adamsredlines said:Its always good technical advice to compare an engine to a pool.
The setup wont really run any diff than a 3" si/so dumped exhaust, which alot of guys run..{It will sound better however if you exit on either side}Nathan K said:I just got a Magnaflow 3" SI/ 2.5" DO, going on a bone stock 4.7l. Is there any reason not to run 2.5" DO on my 4.7. If so, why? Ive read to stick with 2.25" on a 4.7, can someone give me a detailed explanation as to why?
AIR_RAM said:Your right, it does... if you cant GRASP the theory of opporation it does help to be able to understand the subject enough to brake it down to a level that can be understood by someone who does NOT understand the threory of opperation...
Are you disagreeing with the theory of opperation? Perhaps if you knew a "LITTLE BIT" of the THEORY of OPPERATION you would not be so quick to attack people who do. I certanly do not know everything... but I have built several Pontiac engines that have performed well for years... Along the way I did pick up a little bit. You would get a kick out of my 455 which will be belting out in the ball park of 650ft-lb at 3,000 RPMs... NA.
SPEED SAFE, AIR RAM
Well if you think about it, why are you giving advice then... he clearly asked for a "DETAILED" explanation and you took the opportunity to attack "SOME PEOPLE" without even adding any of your extensive experience... He clearly asked for a DETAILED EXPLANATION... The theory of operation does not change. DE DE DEE!adamsredlines said:I dont know I should take advice from someone on the "theory of opperation" who cant even spell it right...
And congrats on your 455, but that has nothing to do with the 287, completely different kind of motor.
