Do they help a 4.7 with an auto get better fuel mileage? And obviously give more snap on the takeoff? Was thinking about putting these in my 04. And how do you fix the calabration of the odometer?
The speedo won't change. You will get better gas mileage and your takeoffs will be fun.Big Blue 1500 said:Do they help a 4.7 with an auto get better fuel mileage? And obviously give more snap on the takeoff? Was thinking about putting these in my 04. And how do you fix the calabration of the odometer?
I assume that is from personal experience, not something you heard from someone once... :thatfunnyMikeHTally said:Just don't expect an improvement on the highway. That mileage will suffer.
Very likely both trucks have over drive, with a final drive ratio of 0.69:1 with the 46RE or 0.50:1 with the 545RE, so that's cancelled out. If one of the trucks you mention has the 545 and the other has the 46, that would account for a difference. I don't think the 545 is used with the 4.7 engine, but I don't know for sure.schawks73 said:Are you taking the overdrive into consideration?
Riddle me this...4.56's DO run at a higher RPM on the highway, but still get better mileage... how?
-David
I will report back in a bit03DakStampede said:my dak has the 545rfe so i wouldnt be surprised if it does KRS on your passenger side of the truck under the hood look at your PCM if you have 4 plugs on it then you have the 545rfe
