The Facts:
1986 D150, 2bb Holley, 2WD, Automatic, 117,500mi, Long Bed, 5th owner
Problem:
Engine doesn't run smoothly. In fact it sometimes spits, sputters, hiccups, stalls and just die starting off from a stand still. Other times, it runs like a champ! No sputter, no sluggish starts, no hiccups. Then a day later, back to the same old, same old.
Let me be more specific:
When driving (at a constant speed... any constant speed: 25, 35, 55mph, etc...) the engine "hiccups." I'm gonna use the letter "M" below to describe the sound/feel of the engine at a constant speed when hiccuping is in process (sound it out to yourself):
MMMMMMM MM M MMMM MMM MM MMM MMMMM MMMMMMMMMMMM
As you can see/hear, there is no real rhyme or reason. No "pulse" or consistency. And though the truck doesn't have a tack, I'd be fairly certain, the hiccups are a drop of 5-600 RPM's.
There is another problem that may be the same or related. While sitting at a stop with the truck in drive (haven't sat still in reverse long enough to know if it happens in reverse too), it almost feels as if the truck lurches and then there is a drop in RPM's.
New stuff list: These are all the updates in the last 2 months/1000 miles that offered no change in performance:
Gas (even tried high octanes and octane boosters)
Voltage regulator
Interstate Battery
Fuel Filter
Air Filter
Rebuilt Holley Carburetor
NGK Spark Plugs
Wires
Distributer
Rotor
Front brakes & rotors (obviously not engine related... I'm just saying)
also, 4000 miles ago, I replaced the radiator and put on new tires
I also check the timing and it was good too
I need HELP!
Problem:
Voltage regulator
Interstate Battery
Fuel Filter
Air Filter
NGK Spark Plugs
Wires
Distributer
Rotor
I need HELP!
