For anyone who has gone with a 305 width tire would you make the same choice again or would you have stayed with the 275 tire width? Thanks Robert
wonder why....dont u rotate your tires??slvrmagnum said:I have 305's also, yes I would do it again and will in Jan when I need new rear tires.
absolutely not...HemiRamOn22s said:wonder why....dont u rotate your tires??
Ok so replace 2 tires every 10k or 4 tires every 30k....hmmmslvrmagnum said:absolutely not...
I would rather only replace 2 tires adn not 4 at once... I get perfectly flat wear on the fronts, so no need to rotate... so now when i get my new ones to replace the rears, I will put my old fronts on the rear and put the new ones on the front.
Where is your logic even founded??? I dont see how pulling milage numbers out of thin air proves your point... why would I be replacing 2 tires every 10k miles?HemiRamOn22s said:Ok so replace 2 tires every 10k or 4 tires every 30k....hmmm
