Hey guys! I have a 06 with the Eibach rear 3" lowering springs and i am thinking of getting the Flowmaster 17400 cat-back exhaust system. Will there be any clearence problems with using the 17400 on a lowered D ?
Thanks
Should not be a problem - the exhaust doesn't hang down...
When I still used my Mopar cat back it was a real PITA to un/reinstall it after I had the D lowered. You dont have as much room above the axle after you have it lowered, as apposed to stock height, but with the Flowmaster not being as wide as the Mopar kit you might not have any issues at all mounting the piping together.
I have the 17400 and my rear is dropped 1.75" I have been under mine alot and it looks like 3" wouldnt be a problem. There is enough give in the exhaust to make it fit. Keep everythign tight to the front. When my tailpies loosend up and moved back out of the muffler they got close to the right rear panhard bar.
