I have a 87 Dakota with the 3.9. I just purchased it to drive in the winters anyway the problem is that somewhere in its past the wiring to the computer on the pass side fenderwell and to the carb have been hacked up. I would like to install a traditional distibutor in it like you would buy to convert a older V8 from points to electronic ignition. I have looked and not had any luck finding anything so I thought I would ask you guys. I would also like to change the carb to a carter that has no electrics. I know the stock setup works fine but I think that I am missing to much of the wiring to make it work rightt.
