I swapped my 3.55 axles tonight with a lightly rolled Durango with 3.92s. They were undamaged and measured up correctly. The swap went surprisingly smooth.
The front differential was a bit of a challenge with tight bolt placements. 7 bolts total. Three bolts are tricky but you can get them with a 24" extension and a an impact from the driver side wheel well. Half-shafts just tap off and slide/tap right back on. New bolts for the driveshaft would make that easier but not necessary with an impact. This turned out to be pretty cheap compared to a re-gear.
Dealing with the parking brakes cables was the tricky part on the rear. Other than that it was pretty straight forward.
All said and done it was $900 and that included the $150 overnight shipping, it took about 7 hours of work, dozen beers and one large pizza :rck: . If we didn't have to mess with the parking brakes and taking the rotors off of the new axle it would have been no more than a 6 hour switch. Definitley a two person job.
Let me know if you have any questions or if you know anyone that needs 3.55 differentials, Watt stabilizer, rotors, calipers, and brake lines included.
