I am going to make this short. I posted here before and my #8 exhaust valve breaking, got a remanufactured engine and had it installed. Rear main seal started leaking so took it in to have fixed and found metal flakes and cutting fluid in coolant. Drained coolant and kept a sample and gave to the MAJOR NAME engine remanufacturer to have it tested. They wanted to just flush it and give it back to me, I told them no, after you drain the oil and check it I will see. Drained oil and found crap inside the oild circuit too. I told them I wanted a new reman, after arguing with them my truck had pristine fluid in the radiator and the stuff we were seeing is not scale and then arguing my truck didn't have an external oil cooler that caused this they sent me a new engine. We cracked the 1st engine open to find blasting material(sand or glass) in the oil pan and the oil pump was trashed.
They finally excepted to pay me back for the radiator, hoses and thermostat I bought for the 2nd NEW engine and the shop just called to tell me they installed the new eninge and ran it for 30 minutes only to start seeing the rear main seal on this one start to leak. There were multiple things wrong with the first engine other than what I have mentioned here. I know I have no beef with the mechanic, it isn't his fault and he is getting paid to do everything again and again. What should I do next?
My original engine is long gone, they haven't or won't share the information they have come up with regarding the fluid sample that was supposed to be back over a week ago.
They just keep issuing a warranty claim and fixing crap as it arises. I am afraid I am going to get stuck out in no mans land with this truck, I am starting to really wonder if I am ever going to have confidence this thing will get me from point A to point B. I really don't know if they are just going to limp this thing to the warranty limit and them I am stuck with a piece of crap...
