http://www.dodgetalk.com/forums/showthread.php?t=102318&page=3&pp=20
I read the "how to" on this post. I would like to provide some detailed feedback.
I perfrormed this trick recently. It was a mixed bag.
The spring hanger flips over, and 2 diagonal holes line up, and the others need elongated, as slammed1 says. The holes that lined up on my truck were front lower, and rear upper.
This took 4 "above average" wrenches 6 hours to do, on a lift, with adequate tools, but no torch. A torch is absolutely critical for this job :VHOT: Air chisel takes off the rivet heads, but the rivets to not just punch through and we ended up drilling. I believe the bolt holes are 1/2, but check to make sure. We bought 14MM (9/16)bolts, and they were larger, necessitating opening up the holes larger then needed. Since this was done after hours, there was no close hardware store.
The frame is double wall thickness, on my 96 club cab. Tons of drilling.
The leaf does not need to be disconnected, you can just turn the spring hanger around.
With a 2' rear shackle, the truck is .5 away from the bumpstop. Ride is rough (hitting bump stop) but will probably be better once bumpstop is removed. With 4" of drop, (I already had rear shackle installed) I doubt stock shocks will be happy, but I will decide once bumpstop is removed.
1996 Ram club 2wd. With shackle, and flip, no front end modifications, the rear sits exactly 1" lower then front.
Tools needed:
TORCH :VHOT:
Air chisel
drill bit 1/2 SHARP
1/2 grade 8 nuts and bolts, with flat and lock washers
Directions:
Remove tires
Support frame
Support axle, floor jack preferable, for adjustability
Heat rivet head, and air chisel head of rivet off
Drop axle, to lower front of springs
Heat rivet in frame and punch through
Rotate hanger
Bolt up front lower and rear upper
drill out rear lower, and front upper
bolt rear lower and front upper./
Tools needed:
TORCH :VHOT:
Air chisel
drill bit 1/2 SHARP
Directions:
Remove tires
Support frame
Rotate hanger
