1 - 9 of 9 Posts
Been working on all the shit i broke wheeling one day and 1 of the parts is the t case casing. Were can i buy the front part of the casing? The part the bolts on the overdrive housing on the tranny. If you know please give me some websites. Thanks ahead of time.
ya got lucky and found the part on ebay. Just the half i needed. shipped for $68.00
Discussion Starter #4
Anybody out there know a website that tells you how to rebuild a 231 t-case? I need to replace the front part of the casing and need to know how hard it will be to do. Anybody know?
work in progress
t case is pretty straght forward to rebuild if you are a average mechanic you can do it without a manual 2 shafts a chain to connect them a pump and bearings
Discussion Starter #6
****! i bought a new casing n231 d. my old 1 has a 3 pinon planetary gear in it and new casing i bought has a 6 pinon gear in it. Whats the difference of the 2? ring gear the same?
work in progress
the 6 pinion is stronger it distributes the load better and means longer life
thats nice but will the front half casing with the six work on mine?
work in progress
it should work fine you can test fit everything first just to make sure
1 - 9 of 9 Posts
