Awesome. I had a code when I first got my van, and took it to the local mechanic. He couldn't seem to figure out where the problem was, but told me that the code was for the leak detection pump. He reset the computer a couple of times, and after the third time, the check engine light stayed off long enough for it to pass inspection. Shortly afterward, the light came back on, but I didn't worry about it. Fast forward 10 months, and my inspection was coming up again, so I decided to have a look. It took me about 30 seconds under the van to spot a vacuum hose hanging down just inboard of the drivers side front wheel. A closer look revealed a bolt shoved into the end of it. Just above it was a plastic module, which obviously had a vacuum fitting broken off. I figured that was likely the leak detection pump, and was right. A quick trip to the local Dodge dealer, and $130 had me a new pump, and the check engine light off. I'm not quite sure why the mechanic couldn't figure that out, it wasn't terribly difficult, and I'm sure he knew what the leak detection pump was in the first place which should have made it easier for him.
