I have a 2016 Grand Caravan with sealed transmission. I am approaching 103k miles. Service schedule says 120k miles. I will have it serviced this summer before a major trip we have planned in August. What is the service process for a sealed transmission? Is there a filter to replace? Is this a simple fluid exchange done by machine?
The normal service process is to remove the transmission pan and allow as much fluid as possible to drain, remove and replace the filter, reinstall the pan and refill with ATF+4 fuild to the proper level.
Also note that the transmission isn't really sealed, it just has a quarter turn plug in the transmission fill tube that is marked "For Dealer Use Only". The fill tube is also where the fluid level is checked using a special dipstick.
This special dipstick, I'm sure one can be made. Do you know where to find specs and measurements?
Sent from my SM-G973U using Tapatalk
