Looking at getting a new set of tires for my 2014 ram 1500.
Stock tires are 265/70r17 but now have 18” rims and looking at 275/70r18 tires. Have seen a lot of info about not exceeding 3% for tire size increases and also a lot saying that it wouldn’t hurt as much as people say.
just wondering if anyone has any input on what kind of impact I could expect on other systems of the truck by going to the larger size
thanks
Red Trucker
What gears do you have? Your new tires would be almost 2" taller. This will throw your speedo obviously, but it will also change your final drive ratio a bit. If you have say 3.21's, they're gonna feel probably closer to 3.08's with the extra height. You also didn't mention the width on the 18's; going to a 275 safely without a bunch of sidewall bulge usually requires a 9" wide wheel. Other than that as long as it's the same size tire front and back (if 4x4) it won't affect anything else.
629338
Thanks for your reply. The rims I have are 18x9 mayhems so we’re good there and it’s 3.92 gears 5.7 Hemi w/6 speed tranny
Is this a 1500 or 2500? Ram 1500's got the 8sp starting in 2013.
I got robbed! My 2013 ram 1500 has a 6 spd tranny
And I went with the 18s and my trk rode a lot better. Especially on turn radius, but that was a 2008 dually, I’ll shut my mouth now😬
