1 - 2 of 2 Posts
Hello,
I've been having some problems with a 2013 Dodge Grand Caravan
The whole passenger sliding door seems to lose power intermittently where the power lock, window and sliding door motor will not work. But the rest of the doors have power and work normally.
Also when the power sliding door does work, it will only close 80% of the way, and you have to manually close it the rest of the way.
Already replaced the sliding door module, but the problem still there.
Any help would be appreciated
Thanks.
Hello,
Thanks.
Hi macman32,
Sorry to hear you are experiencing this. We understand you are reaching out to fellow forum members, however if you are not able to remedy this concern with the advice provided here; we kindly recommend connecting with your local Dodge dealer. If you are in need of any assistance with that process, our team is available via private message.
Rob
Dodge Cares
1 - 2 of 2 Posts
