Misfiring cylinder 7 changed all the coils spark plugs fuel injectors. N still misfiring on 7 I take the plug out on 7 n they came out black carbon..dry.i Need help in fixing my truck.??
You would require the total motor arrangement and perhaps the transmission also to make it work. The motor wiring, ECU, exhaust framework with felines and O2 sensors are completely required. In all likelihood the transmission you have isn't equivalent to the 2012 truck which implies it would not work effectively with the more up to date ECU. On the off chance that you can purchase the giver truck total it would be ideal.
Kodi Lucky Patcher nox
